Installation on Linux Mint?
sdim
Hey, everyone.
I've been trying to install FreeFileSync on Mint (donation edition).
While I was previously able to double-click and install it, I can't anymore.
I had to use AI help to install it on Mint 27.
Now when I open it there is an update but clicking on it gives an error:
Command ""/tmp/FreeFileSync_14.13_[Donation_Edition]_Linux_Install.run" --directory "/opt/FreeFileSync" --autoupdate" failed.
Exit code 1: Could not find path to a terminal executable.
Any ideas?
Which terminal are you using (and at which path is it located)?
sdim
The new Linux Mint (27) uses Velocitty.
/usr/bin/velocitty
Can you run:
cat /etc/os-release && ls -la /usr/bin/*term* /usr/bin/velocitty
