I would like a new feature to use an offline directory structure as a new connection type. When using this new connection type, the synchronize button would be disabled.
My current offline capture tool / format
https://github.com/rlv-dan/Snap2HTML
Offline Readonly Compare
I'll just note that with Everything, you can have @offline volumes@.
[The @ are quotes, but my keyboard is messing up, currently.]
I (update) & keep a copy of my home computer drives/files, that I
then (sneaker-net) to my office computer, giving me access to
information on all my home computer files.
I can search/filter, any which way till sunday, while seeing any data,
file properties or what, assuming indexed & exported, that I want.
https://www.voidtools.com/everything-1.5/
