Jumpin file drive letters
mrick117
It seems Win 7 will periodically change my drive letters for my external drive. I have Windows task scheduler backing up some of my drives to my NAS. But I worry that changing the drive letters around will result in the wiping out of my "real" backup data.
For example, say I have my iTUNES on Drive E and I use FFS to backup drive E to my NAS. Then windows changes Drive E to Drive D and assigns Drive E to a different external drive. If I don't catch it, I am concerned the revised drive will result in backing up the wrong thing and wiping out my library.
I have tried to assign a "static" drive by my reasearch says there is nothing I can do about that. Is there a safegaurd that would prevent this loss of my backed up data?
srjones67
Create a batch that tests for the existence of the drive specifically the drive letter or contents before running the sync.
FFS supports variable drive letters by referencing them by volume name. See help file chapter "Variable Drive Letters".
A second safe-guard is that FFS checks if, roughly speaking, 50% of files will be created or deleted, which catches the situation where you assign the wrong directories for synchronization. This is shown as a warning in case you have not setup errors to be ignored, which would ignore warnings, too.
mrick117
Quick reply - thnx. BTW I am using mirror.
I will have to think about your solution. If my batch could check for a test file before going to the next step, that would be pretty neat. Not sure how to do that but I will give it some thought. Testing for just the drive letter won't help - it will always find the drive letter.
Let me ask you this. If my batch attempts to backup Drive E/itunes and W7 changes the drive letters; and the new Drive E has no folder called "itunes".... will the batch just abort? If it does that, I just have to make sure I don't duplicate the file structures in my various external drives.
mrick117
A second safe-guard is that FFS checks if, roughly speaking, 50% of files will be created or deleted, which catches the situation where you assign the wrong directories for synchronization. This is shown as a warning in case you have not setup errors to be ignored, which would ignore warnings, too.Zenju
Hi Zenju -
You posted while I was responding. Thanks for your quick reply as well.
I will look at your chapter "variable drive letters". On the batch files errors are always igonored so that won't help.
Great product and thanks for your support.
chutia
open the software and go to help file, look there. i was searching for it on the website. :P
