Always play sound when finishing comparison & sync?
dirki-boy
How could one make it, that always after comparing and syncing an audio signal of your own choice sounds? After every update you would have to add your own sound files again, something like a check box "Play sound" would be good.
New with FreeFileSync 10.13: notification sounds are managed via the global options dialog
