Hi!
I would like to request a theme user based custom. Currently freefilesync is not synchronized in my current windows classic theme.
I would like to have freefilesync has its own builtin user custom theme.
1. Windows background color (also the frames and/or bar frames).
2. Text (Global/Universal) Type / Size / Color / Text Background Color.
(theme setup like notepad++ which advanced i think)
Thanks.
Request - Theme User Custom.
I would think that FFS uses the system colors most of the time. Do you have a screenshot showing the parts you think are not right?
Hi Zenju.I would think that FFS uses the system colors most of the time. Do you have a screenshot showing the parts you think are not right?Zenju
Not because its not right its just dont like it. Sample provided.
Could make the white background to be totally black.
Hoping for builtin theme.
Mia
The problem is, whenever either background or foreground color is hard-coded by the program, the other color needs to be hard-coded, too, to support accessibility. In the progress dialog the graph lines are hard-coded.
