Replace Windows File/Folder Copy Command
miamoore1993
Hi! Again.
I am aware that this is a sync application. And maybe youll wanted to stick with it. But I wanted this to function also as a normal file/folder copy command. When start copy it will show the ffs progress window - even youll copy a single or small size.
Maybe someone already requested this.
Thanks. :)
petrovski80
If you're still on Windows XP I can understand your request since the GUI feedback for file operations is very limited on XP. You might want to take a look at this program: teracopy
