FFS can not copy my files from my hard drive to my server
stephrodr
I use FFS 5.21 and netdrive 1.3.4.0 and connect to my site is done correctly, I view the files on my site.
When I run a comparison between my hard drive and my site is FFS differences. When I run the synchronization, FFS was able to remove my files on the server but against it can not copy my files on the server.
For cons, I can copy files from my hard drive to the interface NetDrive.
I deduce that there is a problem with FFS.
I did some quick research on the forum but a priori I have not found the answer to my problem.
Thank you for your help.
petrovski80
Can you copy files manually with a windows explorer instance running with highest privileges (as administrator) to your FTP?
