Win 7 64bit UAC off
FFS 5.22
I have used FFS in the past on other machines to do this same thing but it is not working now. I am trying to sync 2 drives (E+F) but when I click compare it takes a second then comes back with no differences. There is 1.5 TB of data so I know it is not scanning all that.
E drive has data. F drive is currently empty.
It does not give any error messages and if I click SYNCHRONIZE, the log just says nothing to synchronize.
If I select a subfolder on the E drive instead of the root then compare works. Where do I go from here?
Cannot sync root of 2 drives
