I've edited some files on my local hard drive and run FFS to sync the changes to a NAS. FFS reports all files in sync almost instantly, but the changed files aren't being copied to the NAS.
The only "odd" thing I can think of is that I copied the NAS contents from another machine - presumably any ffs specific files (I can see folders called FFS 21014-04-09 232945 in the root directory) have also been copied. Any suggestions? At the moment, I have to copy the changed files across using Explorer, which sort of defeats the point of FFS.
FFS reports all files in sync, but they aren't
I think I've solved this; I changed the setting for Symbolic links from exclude to follow - is this a new option in FFS? It worked last time on this machine (around 4 months ago).
-Andrew
-Andrew
