Is is possible for FFS not to create sync.FFS_lock on the source folder if "Mirror" is needed? After all, it is a read-only for the source folder.
As I am using a Sharepoint, creating a file on the network will trigger the folder owner an alert. I would like to avoid that. Thanks!
Q: for "Mirror" sync- Can I stop FFS from creating sync.ffs_lock?
You can disable the lock file if you don't need it: see help file chapter "Expert Settings".
