I just want to check if following situation is not possible:
- synchronization is activated for folder and subfolders with "mirror" setting, and one of the files in one of subfolders should be synchronized with "two-way" setting
I've tried exclusion in main task and adding additional task just for this special file, but as expected this doesn't work, this file is completely skipped in synchronization because in one of the tasks it is excluded.
Sync subfolder files with different sync settings
You can enter filters at folder pair level. So just use two folder pairs with different sync and (local) filter settings.
Yes, I've already done that and that is working. This is not important, but consider possiblity of exclusion that is implemented on one task and ignored for other.
