trying to get this to run automatically on windows 7. set it up as a task in task scheduler OK so i could run it with elevated privileges to get around UAC, that works.
created a short cut to run the task, all works fine the only problem is RealTimeSync sits there waiting for me to hit the start button when i use the shortcut, how can i get around that, any help please?
realtimesync
it's OK i got it to work. I needed to be passing the saved RealTimeSync configuration file as an arqument to RealTimeSync when running it as a windows task for elevated privs (by-pass UAC)
cheers
cheers
