Integrity error with windows version 6.x (on windows 7)
rbadillarxxx
Hi all:
I recently download the file for windows version (installer) the md5 is fc316051c5da50c6cecf0acddd395c89 and the size seems to be 10,1 MB (10.604.544 bytes).
When I try to install it says:
"Installer integrity check has failed. Common causes include incomplete download and damaged media..... " So this is a heads up! and why is so hard find the md5 from the publisher?
Thanks a lot!
PD: The KAV says its virus free.
Where did you download FreeFileSync from?
The file size for the v6.0 installer should be 11.560.656 Bytes and the MD5 9e6a6d8be8043cc9f46c76a7affa8533
rbadillarxxx
Hi Zenju I downloaded at first from fosshub.com. After I use sf.net and size (11,0 MB (11.563.008 bytes)) and checksum were different. As you can guess the installation was fine and the program worked like a charm!!
