I use FreeFileSync at home and sometimes syncing goes on until the late hours at night.
I find it most disturbing that FreeFileSync has to emit a sound when it finishes a job. There is no option to silence FreeFileSync.
I checked the installation folder and the Windows Sound manager; there is no way I can silence it.
Could you please make this sound thing optional.
Thank you.
Getting rid of sound
If you set up the sync as a batch job there is no sound at the end.
The "official" way is to delete or overwrite the "Sync_Complete.wav" file.
New with FreeFileSync 10.13: notification sounds are managed via the global options dialog
