Hello Zenju,
I just discovered your tool and I really appreciate your work, this is truly needed, especially on Mac.
I noticed how the UI is fairly confusing and could use some design help. If you're open to that, I would help you out for free. It wouldn't take much to make the app a lot better, just a few tweaks here and there to make the UI a bit clearer.
Let me know if you're interested.
p.s.: just to let you know I'm not joking, check my profile > http://www.linkedin.com/in/lucacandela
Offer for UI help
can you give an example of what you would improve an how? There has been put considerable thought into every tiny detail of the GUI, so there are probably no low-hanging fruits left...
hi Zenju, indeed you're right: the GUI is well done and it's obvious you put a lot of work in the details too. Although everyone may have different preferences, i think the interface is clean and clear, and easier to understand than many other sync-programs.
Keep up the good work and thanx.
