there is a problem exiting FFS. When i close it (either by using the menu or by using cmd-Q), one process of FFS remains active. While FFS runs, there are two processes name FreeFileSync in the Activity Monitor, and when i close FFS, one of them remains. This is mainly a problem when updating FFS, because i have to kill it by myself, but i think a program should be able to shutdown itself completely.
I am on OS X 10.9.1, running FFS 6.1 (but the problem has been on the earlier versions too).
Regards
Matthias
FreeFileSync does not close properly on OSX Mavericks
This behavior is similar like for other document-based applications like safari. Even when when all dialogs are closed, the main application is still running as can be seen by a marker in the OS X dock. This marker is not shown for FFS, but I'm not sure if that's more than a cosmetical issue. Generally, this second FreeFileSync monitoring process is needed in order to handle mouse double-clicks on .ffs_gui and .ffs_batch files correctly.
