I have the realtime scanner running with a batch file input. When it kicks in the 'scan' of the source and destinations, the 'scanning' dialog pops up.
Whilst it has the 'minimise' down arrow button, is there any way to avoid it ever popping up at all, only working in the background as a minimised systray app?
FreeFileSync SCANNING dialog
You can uncheck the "show progress dialog" checkbox in the ffs_batch creation dialog.
Excellent, worked a treat. thanks so much.You can uncheck the "show progress dialog" checkbox in the ffs_batch creation dialog.Zenju
