save/ restore File Progress dialog size/ position
Would it be possible to save/ restore the File Progress dialog size/ position? When I click Synchronize the first thing I always do is maximize the graph because it always defaults to a fairly small window.
I have almost the same problem. The first thing I do after pressing the sync-button, I move the window in the center of the screen. That is really nerv-frecking!
Please let the window save its position or at least set it on center of screen or full screen.
I've fixed the code to make the sync progress dialog center correctly on its parent window.
Please give us a maximize button in the right top corner of the graph screen, so we can read the entire lines in the log after synchronising.
Thanx very much and keep up the good work. I love it!
Hello everyone,Please give us a maximize button in the right top corner of the graph screen, so we can read the entire lines in the log after synchronising.
Thanx very much and keep up the good work. I love it! Arno, 13 Mar 2017, 15:08
Can someone answer my question, please?
Thanks!
Unrelated to the original topic. Anyway, the maximize button is already there.
Sorry Zenju,
In the sreenshot for Windows I can see the maximize button, but it is not there in my version for Linux Mint.
Only a screen closing button "x" is there.
Would you please fix this in the next update?
Thank you very much!
Can you post a scrreenshot?
Here is my screenshot.
- Schermafdruk van 2017-03-30 14-44-35.png (24.96 KiB) Viewed 1558 times
This may be due to Mint preferences: https://forums.linuxmint.com/viewtopic.php?t=218453
Dear Zenju,This may be due to Mint preferences: https://forums.linuxmint.com/viewtopic.php?t=218453 Zenju, 30 Mar 2017, 12:55
I looked into it and I cannot get it right, so let's leave it alone. Thanks anyway for your effort.
Maybe it is possible to alter your code for the screen to open maximized as a default?
Thanks for now.
