Error code 22 - Ubuntu 13.10
talestomaz
I used to have Ubuntu 13.04 and FreeFileSync worked perfectly. But since I have upgraded Ubuntu to the 13.10 version, FreeFileSync can't create anymore directories. When I try to sincronize folders and it should create a new one, it returnes de "error code 22 (mkdir). I've already updated FreeFileSync since I have Ubuntu 13.10, in order to see if this was the problem, but I didn't notice any difference regarding to this issue. The problem occurs in RealTimeSync as well as in FreeFileSync. My current version is 6.0.
Any idea?
Thanks in advance!
talestomaz
Something new? I have already uninstalled and reinstalled FreeFileSync and even so the problem is still there.
talestomaz
I've just discovered what's the matter and perhaps it can help someone else. The name of the folder had a word between quotation marks and that's why FFS wasn't creating it. Coincidently I created that folder exactly before upgrading Ubuntu.
talestomaz
I discovered another situation that causes the error code 22 (at least in Ubuntu, I don't know how it works in Windows). When I named files with a colon (:), FFS couldn't make the synchronization. I just renamed the files, supressed the colons and it went ok This might help someone.
