Problem sync.ffs_lock - Shutdown synchronization
taserback
Hello everyone,
I use FFS to sync files from my pc to my Synology DS209 when the computer Shutdown.
I use a script to start the batch FreeFileSync. The task starts well, no problems at every shutdown but sometimes, i have a blank log file and when my pc restart, I get on the desktop sync.ffs_lock file.
I tested to run the batch directly under windows and synchronization goes well with no problems and my log is good.
The problem occurs just when the PC turns off.
Here are the steps:
I click on the "start menu" and then "shutdown the computer".
The script launches the batch FreeFileSync.
The window FreeFileSync appears and examine the disc before playback synchronization.
The synchronization starts.
At the end of the sync my pc is shutdown normally.
Whent the the pc restarting, I get a file on the desktop sync.ffs_lock.
Where comes the problem.
Thank you for your help.
Taser
