filter suggestion
rickc100
It would be nice if you could preview the files that will be filtered so you can check your filters. On a large disk it takes a lot of scrolling to see what files will be excluded plus it is easy to miss while scrolling.
Or have a window to put in a potential filter and have it scan a disk and show you what it would apply to. If you like the results a 1 click to add to the filters.
Also it would be nice if there were some sample common filters included so you could import them when installing a new machine. Also if you could export your filters for easy transfer and sharing of filters.
It would also be nice when building filters if you could click on a line in the main window to have it trasferred over to the filter window for editing after doing a test compare.
