problems...
matteobraga
Suddenly freefilesyncr that is properly installed (6.5) does not work, selected source files (network) and destination (local) start of the synchronization, but does not find the files you want to sync (although there are several). I added freefilesyncr exceptions in the firewall, but nothing changes. Do you have any ideas? thanks
Maybe you have the filters setup incorrectly in FFS?
matteobraga
I solved, back to a previous restore point to winxp, uninstalling everything, cleaning the registry, re-installing freefilesyncr 6.4 and recreating the rules ... the update to 6.5 was not a good thing ...
Thanks... :)
