First of all, thanks to the author(s) for such highly useful software. It makes things so much easier.
This is not a complaint. It's simply an idea. It may be completely wrong and I won't be offended if you tell me so.
We use FFS in a WAN setting. The scanning and synchronization takes a while over those slow links.
So, the goal is to speed up scanning and synchronization over networks. The proposed methods would be...
- Locally scan each computer and communicate only changes across the network.
- Compress data before sending across a network, then decompress on the other end.
These could be accomplished by writing a remote agent that communicates with FFS, or simply adding remote functionality into FFS itself (so multiple instances of FFS could talk to one another.)
That's it. What do you think? Am I crazy?
NoDough
Feature Suggestion: Remote Scanning
