Hello sir,
FFS is a beautiful product, I have some suggestions :
1. Configuration pane: profile last run date time and status.
2. Whenever a folder is selected in overview pane, Only its own contents should be explored in the main window (currently contents are highlighted from left in blue color)
3. Button arrangement(main toolbar):
Left(compare setting, sync setting, filter)
Right(compare button,Sync/Mirror button)
4. Sync button should be disabled until compare button is clicked and comparison finished. This cycle should be repeated for every comparison.
5. Facility to switch progress graph window with progress bar, So that overall progress can be monitored by a progress bar built inside the main window (without opening in new window).
Thanks,
Feature Requests
