Hi Zenju,
First, thank you for your great utility, have been using FFS for years now. Which is why this request is slightly embarrassing...
Today I wanted to change the location of the results log file (generated by a FFS batch file). Do you think I could remember where the setting was? No, I couldn't. I searched the help file for 'log' but that is no help (Try it). OK, so after 10-15 minutes I finally re-discovered what I should have already known and made the change.
The information IS in the help file (Schedule a Batch job) - but since it is a graphic it does not show up in a search. So, that is my suggestion - put text referring to the log file on that page so it shows up in the help search.
Thanks again, all the best to you!
Results logging in Help file
