New feature - E-mail Report
binde74
Hello.
I think that FreeFileSync is absolutly the best software for file synchronization.
The easiest, the quickest...! Really compliments.
Just a note: You should include the ability to send detailed e-mail report at the end of each job.
It would be fantastic!
Regards
Emanuele Bindellari
Italy
boris.bahes
+1
You can define any *.exe or script to be run upon completion of your FFS sync.
You can enter the "On completion" command in the FFS Synchronization (F8) window.
Simply call your favorite E-mail program and send e.g. the FFS sync-log as an attachment.
Done. Email notifications are now directly supported since FFS 10.20!
