I´ve discovered this nice tool FreeFileSync in internet and I´m very impressed about features and fast synchronization.
For some project reasons I need an overview about more Windows file attributes to compare BEFORE start sync, this means more than current attributes used by FreeFileSync.
In best case all approx. 290 possible NTFS file attributes and also an export feature for all found files including filename and all of their attributes in CSV file for example.
Unfortunately I didn´t found this feature in current version & help file ;-(
Can you support me with a tip of how to discover and export all file attributes in an export file and/or are you able to add this feature to your software?
Thanks in advance, Kosta
Collect all file attributes for max. syncronization flexibility
Setting up some custom command via menu->tools->options might do the trick. Is there some command line tool that displays these attributes for each file? BTW what are those 290 NTFS attributes?
