small bug: summary stats don't update after a folder gets removed from sync operation
travelid
When the user unchecks a folder that FreeFileSync wanted to synchronize, the summary stats don't update at all after that change. Normally after unchecking a folder, the total size and number of files to sync should automatically reduce in number because now 1 folder is excluded from the sync operation. Hope this helps!
The "Overview" panel is an aggregated view on the file list window, not a synchronization preview. Therefore excluded items will be counted, except when they are also hidden from the file list window, e.g. by unchecking the corresponding view filter buttons.
