Your FreeFileSynce is nearly perfect for me very quick and 2 Folders fields to check but i wouldn't give you a paypal donation cause i missing something what is very important for filemanager. It is MD5 or Sha1 check and copy the MD5-Hashes[Hex] to Excel-File. If you integrate it i will very generous.
But 1 Bug i found...the File comparision didn't work if you search as byte for byte! I test it with exact the same image-file *.jpg only the name was different. FreeFilesync didn't find it! Other programs found it. Test On Windows 8.1-System.
MD5 or SHA1 to proof Files...why not?
