minor flaw:FreeFileSync_6.12 shows wrong version number
usefoolpeople
i downloaded FreeFileSync_6.12 from a mirror:
[404, Invalid URL: http://ffs.winsoftware-forum.de/FreeFileSync_6.12_Windows_Setup.exe]
at FreeFileSync/help/about it shows me the
versions number: FreeFileSync 6.5
build: may 1 2014 - Unicode x86
at FreeFileSync/help/udate/test
it shows me a new version 6.12 is available
i use the german language version
useful tool thank you
With friendly regards usefoolpeople
I'm not able to reproduce this with the version linked above. Chances are you inadvertently are still using the old 6.5 version.
usefoolpeople
I'm not able to reproduce this with the version linked above. Chances are you inadvertently are still using the old 6.5 version.Zenju
you are right
i used a old version installed in a other folder
i have to delete it
thanks for your fast reply
Goodby!
usefoolpeople
