It would be great if there was an option to do a CRC compare of a file after it has been synced to a device.
Scenario is I have the Sync process set up to sync files by Date/Time but would want to make sure that any newly synced files are verified via CRC compare. This is similar to ViceVersa feature.
Feature Request: Verify synced file by CRC compare
As per Zenju suggestion please read this first:
http://blogs.msdn.com/b/oldnewthing/archive/2012/09/19/10350645.aspx
Then read Zenju's post: viewtopic.php?t=1495&p=6292#p6292
Excellent! :)Hi,
Then read Zenju's post: viewtopic.php?t=1495&p=6292#p6292magicool
