Oops, Looks like this has already been requested in "Enable/Disable folder pairs" thread.
Wasn't looking for Enable/Disabe when I was searching.
I would like to see a check box by each folder pair, and a select all check box in FreeFileSync
That would allow you to run only against folder pairs you know have changed or use the select all box to run against all folder pairs.
Feature Suggestion
