Feature request: variable drive letters for network drives
ferblaha
actually the variable drive letter feature only works with usb sticks. It would be very usefull to have this working also in other types of storage devices, like maped network drives.
Thank you.
Fernando
srjones67
There is it's called UNC. \\server\share
ferblaha
That wasnt exactly what I ment... I know you can use that path format, but I mean to access ANY drive by its label, just like you can with usb sticks.
richardw
Same as ferblaha. That post was over 4 years ago.
Variable Drive Letters works on one computer (Win10 1803), but not my other one (Win10 1803 also).
Is this a Windows or FFS issue, FFS design?
Using TrueCrypt to mount an encrypted file.
Earlier 13May2015 post,
by ferblaha • 13 May 2015, 13:28
If they're both using the same version of FFS, then it not an issue with FFS
richardw
Same FFS, but it's the Portable i'm using.
Worked using 10.12, but not when i jumped to 10.18. i agree, seems like it shouldn't be FFS.
Any suggestions what i might try? i tried recreating the FFS config, and unmounting remounting filesystem, and more.
