Dear Free File Sync,
Request for Enhancements (RFE):
I have had to remove Free File Sync (FFS) do to problems with it. I am sorry, I really tried. Would you please consider the following enhancements to FFS to bring it up to more universally usable state?
1) install a real "bugzilla" so that bugs and RFE's don't have to go on a discussion site. This is a much more professional approach than using a discussion site.
2) Arhcives is a nice feature. Gives history. Problem: too much of a good thing. Please add the ability to cull the archives by archive size and/or date.
3) FFS only uses Volume Shadow Copy when it finds a lock on a file. This causes programs that want to
lock a part of a file that FFS is in the process of copying/analyzing to crash. Please change or give the option to "always" use volume shadow copy. It would be bice if this were the default. It would keep folks out of a lot of trouble.
4) set up "include" to supercede "exclude". That way you could exclude everything, then include only the things you want back. Currently "exclude" supercedes "include".
Many thanks,
-T
5) add the ability on this form to be notified by eMail when there is a response
Regarding your item 4), your request seems to be based on a misconception
on how the include and exclude filters work and how to use them.
See my reply in viewtopic.php?t=524
Regarding your item 3), your request makes a lot of sense
and I fully second it as an option.
As the default, it might create a lot of (mostly) unnecessary overhead.
