Bug: FFS doubling "mtp:\" prefix in environment variables
gruberma
When FFS is configured to use environment variables as a source and this environment variable contains an MTP path, the synchronization fails because the prefix "mtp:\" is doubled by FFS.
set x=mtp:\PhoneName
environment variable %x% is now "mtp:\PhoneName"
FFS interprets %x% as "mtp:\mtp:\PhoneName", which does not exist
@zenju: Do you need logs or screenshots to reproduce and fix this bug?
Regards,
GruberMa
Thank you for the report! This little bug has been fixed:
[404, Invalid URL: http://www.mediafire.com/download/k7u17l3zv715xbs/FreeFileSync_7.7_beta_Windows_Setup.exe]
gruberma
[404, Invalid URL: http://www.mediafire.com/download/k7u17l3zv715xbs/FreeFileSync_7.7_beta_Windows_Setup.exe]Zenju
It's working fine now. Thank you!
