thank you for your great tool. Freeware/opensource ar the most best way to spread love and easy handling!
i wish you add a Snyc-Service to Sync Files via Network or Server!
*ftp option
*torrent option
i want to share/spread links with friends from my extern-volume when iam online they can share/auto-sync files from my disk.
if you have detailed quest ask my (but detailed answer in german!)
i want support for it!
i wish you a great future
i will be donate for you!!!
FreeOnlineFileSync
I'm not sure exactly what it is you want to do but I use FFS to sync to local Dropbox, etc. folders which then get synced to the cloud in the normal way. Works nicely.
You can even set up RealTimeSync though I prefer to sync once or twice a day.
