default button
in previous versions, I pressed enter right after launching freefilesync and it started comparison, with 7.1 it opens settings dialog. Please change the default button back to compare
Fixed for next release. Thanks!
just a small suggestion, after the comparison finishes, can you please set focus to synchronize button?
Makes sense, at least partially I guess. But there may be scenarios where it's better to restore the focus to the old control.e.g. navigating the config list or tree panel, then press F5 to start comparison.just a small suggestion, after the comparison finishes, can you please set focus to synchronize button?roberts8
I've implemented the following logic for the next release:
1. comparison is cancelled: restore focus to the control that had focus when starting comparison.
2. comparison succeeded and focus was on comparison button: set focus to sync button
3. comparison succeeded and focus was not on comparison button: restore focus to the control that had focus when starting comparison.
great! thanks
