GUI for restores?
snappel
I use versioning when I backup using FreeFileSync. If I ever have to do a
restore, I'll copy the files over, and may have to rename some files (due to
the naming convention used for storing versions).
Is there a GUI that'll do the restores for me - allowing me to select which
versions to restore and handling file renames as well?
thanks
No, this needs to be done via Windows Explorer.
