I received the below error message on 2 ffs_tmp files in my right folder. I
have mirroring set up.
Windows Error Code 32: プロセスはファイルにアクセスできません。別のプロセスが使用中です
It says that it can't access the file because another process is using the
file.
Anyone have any ideas on how to fix this?
Thank you
Unable to delete ffs_tmp files
Are you using the most recent version of FreeFileSync? The error message
should say which application is locking the file (if possible)
