It would help me a lot if there was a feature where I could update existing
files on thumb drives to newer versions from my local hard drive. To the best
I can tell, this feature does not exist.
Thanks!
Joe
Feature request: Update existing files only
I do not want to add files to my thumb drives that do not already exist. I
just want to update existing files with newer dated ones.
You can just use a custom sync configuration. Start with the "update" variant,
then disable copying of new files.
Thanks! I looked but couldn't tell that it was there.
Thanks!
Thanks!
