Same Name different attributes
teaboy100
I applogise if I have put this in the wrong place as its my first post. I
think this program is great and love the way it operates. Starting from
scheduled tasks is very handy.
Is it possible to set a rule to rename a file that has the same name but
different content?
For example:
Before sync:
Left Side Right Side
Hello.txt 6kb Hello.txt 4kb
And After Sync:
Hello.txt 6kb Hello(1).txt 4kb
Hello.txt 6kb
This way I could back up files that have been modified as well as keeping a
copy of the original. Obviously you could use a date stamp or something
instead.
teaboy100
Um... the example did not show up as intended!
I meant:
Before Sync:
Left Side:
Hello.txt 6kb
Right Side:
Hello.txt 4kb
And After Sync:
Left Side:
Hello.txt 6kb
Right Side:
Hello(1).txt 4kb
Hello.txt 6kb
"Sync Settings->Deletion Handling->User-defined directory" is what you're
looking for. :)
teaboy100
Brilliant, thats exactly what I was looking for! Thats for your help on this.
teaboy100
um.., I mean thanks for your help on this!
ucaakashi
Hello! Has this option changed on the current version 5.7? Is this now the
"versioning" feature under "Sync Settings | Versioning"?
Thanks!
Yes, it's basically the same. But the versioning naming convention changed
with v5.7, see:
viewtopic.php?t=1827
