Hi
i like your program and contain a nice feature doesn't exist at the other
programs however it doesn't contain an important feature
i guess if you add this feature you will be the best and your free program
will beat the other paid programs.
(i will use picture from another paid program but i will not mention the name)
1- the front window contain of a many tasks
i can start one task in the time or all tasks .
(your program start all tasks and doesn't give me the power and control to
start on task only)
[404, Invalid URL: http://img705.imageshack.us/img705/8803/20339338.png]
2-each task work in separate tab , so it's a good organization feature
[404, Invalid URL: http://img838.imageshack.us/img838/1521/42111495.png]
3-sometimes there are a similar tasks so i add them in one task or one job to
start them by one click and doesn't take a big size in the front window of the
program
[404, Invalid URL: http://img19.imageshack.us/img19/562/43799003.png]
[404, Invalid URL: http://img23.imageshack.us/img23/8990/95138488.png]
some advice
You can use the configuration panel for this job. Merge multiple
configurations via mouse drag or CTRL + left button, or delete individual
folder pairs that should not be synced.
This is basically covered by v5.0 tree view which makes it easier to
distinguish different folder pairs.
to start them by one click and doesn't take a big size in the front window of
the program
Shouldn't be hard to do with the configuration panel and merge functionality.
the program
@Zenju
thanks for clarification
i like your program really and i will use it
