Hey everybody.
Actually I need "If left newer then delete it" and "If left older then delete
it". Can I do these choices?
I have make a backup of my D and I use FreeFileSync to keeping my D cleaned
but the problem is that some files are really huge and it takes me a lot of
time to update them. So I just want to delete them if they have change. There
is any way to do this?
Howto do "If left side newer then ...
You can manually filter view for files that are newer on left (comparison
view) or maybe use a filter for file size to your advantage.
hi! thanks for replying me.
if i will use the filter it will not delete the files at the left side, right?
i need to delete any new file from the left side...
No, the result of synchronization is always that both sides are equal for a
particular row. The file size filter will exclude certain file - pairs from
taking part in the sync process, so they are not touched.
