Dear Freefilesync.
It would be awsome to be able to sync with ex. skydrive or any other online
backup place, så you could use FFS for offplace backup.
Is that a feature you are thinking about, or is that to hard?
Regards:
Monberg75
Skydrive Sync
This should already be possible with the current release. However note, that
Skydrive allows only certain known types of file extensions. Trying to sync
others will result with error 87 ERROR_INVALID_PARAMETER. Additionally make
sure to turn global settings -> transactional file copy off. This will prevent
FFS from creating .ffs_tmp files while copying which Skydrive would reject
with the same error.
