First of all congratulations for the program; is really great.
I have two requests to do:
1) ability to sort the list of external applications in the "global settings"
2) ability to exclude one or more pairs of folders from one profile (eg I have
a profile that synchronizes folders, but I just want to make 50 comparisons of
20)
Best regards. Umberto.
Request of 2 new features
Usually I wouldn't expect the list of external apps being too large. So
sorting manually, i.e. placing the entries at the relevant position should
suffice. You can set the cursor at a specific row before pressing the plus
button.
The second requirement can be easily archived by deleting the unwanted pairs
and NOT saving the changes.
button.
For the first question: ok
For the second: the proposed solution is not so functional!
We use a profile with a lot of folders on a shared network drive. If someone
saves the configuration file after you delete one or more pairs of folders
would be a serious problem for us.
Enable or disable a couple of folders would be much better.
See discussion here: [404, Invalid URL: https://sourceforge.net/tracker/index.php?func=detail&aid=3403508&group_id=234430&atid=1093083]
