Hi there,
first of all: great tool! i very much like it!
i do have some requests for improvement
1- would it be possible to make it check to sync once in X days? so afther
this X days it might give you a popup saying saying like "its X days ago you
last syn, do you like to sync now?" but this just as a advanced option
(default off)
2- would it be possible to add a option to make it auto start sync when the pc
is not used? a bit the same like when a screensaver gets turned on/off
Greets
some request(s)
FFS batch jobs can be used in combination with the operating systems
scheduling mechanisms (e.g. task planner on windows) 1 and 2 are thous covered
externally.
externally.
