Visible Listview or Iconview of saved jobs?
mrbertie
Would it be possible to make use of the large blank space at the bottom of the
window to provide a "quick access" list of saved jobs, perhaps using an
Iconview control?
I personally find that saved jobs are a fundamental feature of FreeFileSync,
and while the little drop down menu works, it is not the most obvious nor
practical way to select the job to work with.
BTW: this program is truly exceptional, reliable and thank you for all the
invisible hours of hard work to make it possible!
The next version v3.13 will implement a GUI redesign:
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&atid=1093083&aid=3121323&group_id=234430]
The next best way to manage multiple configurations is probably merging them
into only a few ones, or directly start FFS by double-clicking a *.ffs_gui
file.
mrbertie
The new version (3.13) is excellent, I can configure everything as I like now.
Thanks for the improvements, and your ongoing interest in the great program.
You're welcome! :)
Very nice idea with the quick access list BTW! This feature would not have
been possible before the GUI redesign, so I haven't thought about it before.
-Zenju
