Music files on one drive are synced with the same files on a network drive.
For some reason, the same songs on the two drives have different dates. (It's
not a FFS-caused problem.) Other than copying the files with the newer date on
top of the files with the older date, is there a way to sync the times and
dates? I hate copying that mean files just to prevent FFS from showing the
files as being different. I'm not sure how the two groups get out of date
sync. I'll have to pay close attention going forward.
Date Sync Question
I sometimes use any one of these tools to change the timestamp:
http://www.portablefreeware.com/index.php?sc=82
Perhaps a simpler solution could be to "compare by size only". This can be
accomplished by setting a big value for "FileTimeTolerance" in
GlobalSettings.xml
viewtopic.php?t=1984
GlobalSettings.xml
