[Problem] - Folder last modified date changes after synchronization
Hello, I want to sync a folder with another (mirror, so dir A --> dir B). The folders are on the same partition (internal HDD). dir A contains multiple folders, which are replicated in dir B after mirror sync. The problem is that the folders in dir B won't have the same timestamp (last modified) of the original ones, after sync. How could I preserve it?
Probably this is a unusual behavior, but would it be possible to add it as a feature? For example by making it defeatable through the option panel... I tink some other users could find it to be useful, besides me.
