Version 3.8 won't run with WinXP-SP1
ttwrs
Error message...
"The procedure entry point DecodePointer could not be located in the dynamic
link library KERNEL32.dll."
See [404, Invalid URL: https://sourceforge.net/tracker/?func=detail&aid=3018921&group_id=234430&atid=1093080]
ttwrs
I suspect MS has done this intentionally to force folks from 2000, XPsp1, and
XPsp2. The same problem is happening now with apps compiled with the latest
C++. Problem is, there are still a lot or folks unwilling or unable to
'upgrade', so using the latest MS tools (unless there's a workaround) will
lock people out of the latest revs... :>(
2010-06-25 16:39:03 GMT
It's sad that this incompatibility is artificial. Now the burden of fixing it
increases the administrative efforts with each release. Currently it's easy,
but in the long run workarounds are never a good idea...
